WiFi strength
MKTaylors
WiFi strength
I’m struggling to get a decent signal in my study, I have my main computer there and stream music to the rest of the house and it keeps dropping out
I have done a strength test and it can drop to 77 dBm , router is two rooms away by the fibre connection point
Can anything be done?
4 REPLIES 4
outcast
Aspiring Champion
Fixes: 19
Re: WiFi strength
Run an Ethernet cable ?
MKTaylors
Re: WiFi strength
I can’t run a cable through the house, i need the WiFi to work
outcast
Aspiring Champion
Fixes: 19
Re: WiFi strength
What about powerline adaptors ?
HPsauce
Aspiring Champion
Fixes: 5
Re: WiFi strength
I've just rejigged/extended my powerline adapters after a VERY NEAR (50 metres or so) recent lightning strike blew up one of a pair and I added by "backup" pair to the network. The lightning did more damage in houses nearer and destroyed a couple of pine trees too!
I now actually have a three units (one at the router, two elsewhere) and a mix of manufacturers/specifications (TP-Link and "BT") but it all works well. One is on the same ring main as the primary/router unit, the other on a separate circuit in a house extension, only connected back at the meter.
Broadband is FTTC at about 60mbps and I get >55mbps from devices connected to either "slave" unit.
