WiFi password I correct
Donna412
Why do I keep getting WiFi password incorrect when I’m trying to connect most devices are fine except my sons iPad and xbox
2 REPLIES 2
Thrall
Seasoned Pro
Fixes: 23
Re: WiFi password I correct
That’s generally a generic error message and normally fixed by carrying out the steps here https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966/highlight/true#...
bobpullen
Fixes: 179
@Donna412 you may be subject to the issue described here.
If you are, I have just pushed an update to your router that should help. You'll need to switch it off/back on at your side to apply the update.
Hopefully it helps.
