WiFi issues
- My Router
- WiFi issues
WiFi issues
25-12-2019 11:55 AM
Hi my first post and only doing so as I am so frustrated with my WiFi
I have a PlusNet hub one Router fibre service but my WiFi constantly stops working then comes back on Some time later- prime example is when on search engine the iPad /phone just doesn’t find anything. I have to wait for it to work again before the search provides any info unless I switch off /on router - wired Laptops etc work fine. I also find that when my son is on his PS4 wired connections my WiFi won’t work very well either - any help would be most welcome - been with PlusNet fibre for 6 months and the problem seems to be getting worse. Any help would be most welcome - settings etc
Message 1 of 4
(555 Views)
3 REPLIES 3
Re: WiFi issues
25-12-2019 12:33 PM
Use the SEARCH box for clues: ie., "hub one wifi issues"
Message 2 of 4
(547 Views)
Re: WiFi issues
25-12-2019 12:56 PM
Moderators Note
This topic has been moved from Feedback to My Router
Message 3 of 4
(532 Views)
Re: WiFi issues
05-01-2020 1:57 PM
@Juicebuster, worth having a read of this as it sounds like you may be affected.
Message 4 of 4
(402 Views)
