WiFi issues
cj2018bailey
WiFi issues
Hi, recently switched to your service, speeds are fine and no issues with the actual broadband link, however I'm having to restart the router every day, sometimes more than once due to the signal being lost every couple of minutes, on both 2.4 and 5ghz. No issues with Lan connections. I've tried using various channels after using a WiFi analyser but the same issue arises every day. WiFi worked fine with my previous supplier.
7 REPLIES 7
198kHz
Fixes: 41
Re: WiFi issues
Welcome to the forum.  Smiley
Assuming that was with a different router, it suggests that the current one is a duffer. Can you try the previous one with your PN ID/PW?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
MatthewWheeler
Fixes: 480
Re: WiFi issues
Sorry to hear about the issues you're having.
So we can advise further can you confirm the type of devices you have connected and if they all lose the signal?
Also can you confirm if you've desynced the wireless bands?
 Matthew Wheeler
cj2018bailey
Re: WiFi issues
Unfortunately I've returned the old router to be recycled, mobiles and laptops and a desktop pc drop consistently, Xbox one stays connected all the time though which I thought was odd.
I'll try desyncing later.
Strat
Fixes: 565
Re: WiFi issues
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
DS
Seasoned Champion
Fixes: 22
Re: WiFi issues
That isn't a good idea imho
Many reboots in a short period of time might cause issues too.
But, have you split the wifi?
Click the following - http://192.168.1.254/index.cgi?active_page=9105 - and select no under for the sync with 2.4GHz
Then add something like 5-GHz to the SSID
I'd also suggest adding the same to the wireless key.
The above will then give you 2 separate wifi channels and clearly you'd need to reconnect to to this 'new' one for anything using 5GHz. Having said that, none of our devices use the 5GHz spectrum as we find it very unreliable.
2.4GHz is 'better' when the device is further away from the router
5GHz is 'an option' when the device is closer (from experience in sight of) the router.
LordFoul
Fixes: 32
Re: WiFi issues
That's fine, @cj2018bailey.
Let us know how that goes.
Thanks - LF
cj2018bailey
Re: WiFi issues
Seems to have sorted itself out for now so I'll try the suggestion if/when it breaks down next.
Cheers
