WiFi dropout.
- My Router
- Re: WiFi dropout.
WiFi dropout.
30-09-2019 9:06 PM
Re: WiFi dropout.
30-09-2019 9:25 PM
Only Plusnet can update yout firmware. If you log into your router and check your current firmware version the latest ends .263.
Some wifi drop out problems can be solved by separating the 2.4 and 5 GHz bands see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Re: WiFi dropout.
30-09-2019 10:12 PM
Also use the forum's SEARCH button to see suggestions on improving Hub One's WiFi performance, which admittedly
isn't it's strong point!
You could consider using your previous router, and reconfigure it's settings.
Re: WiFi dropout.
30-09-2019 10:14 PM
