WiFi disconnecting
- My Router
- WiFi disconnecting
WiFi disconnecting
20-11-2020 1:30 PM
I have had issues since joining Plusnet but the worst is that my devices keep disconnecting and some won't reconnect for ages
WPS helps sometimes but I would prefer them to be connected always
My devices include Xbox,2 tablets,2 firesticks,an echo dot and 2 smart TVs
These worked fine with my old provider
I have tried changing channel on 2.4 GHz but no improvement
Would I be better purchasing a better router?
Message 1 of 5
(564 Views)
4 REPLIES 4
Re: WiFi disconnecting
20-11-2020 1:33 PM
Moderators Note
This topic has been moved from General Chat to My Router.
Customer and Forum Moderator. Windows 10 Firefox 101.0.1 (64-bit (64-bit)
Message 2 of 5
(561 Views)
20-11-2020 1:44 PM
Message 3 of 5
(555 Views)
20-11-2020 1:50 PM
Unfortunately didn't realise that I could use my old router
Pretty sure I threw it away
Message 4 of 5
(548 Views)
21-11-2020 1:51 PM
@tigersb I've pushed an update to your router that might help. If you look elsewhere on this forum you'll notice there are a few known issues affected WiFi on the Hub One that we're working through.
You'll need to reboot to apply the update.
Hope it helps.
Hope it helps.
