WiFi constantly dropping
- My Router
- WiFi constantly dropping
20-03-2020 9:36 AM
Not sure how to fix.
WiFi constantly dropping.
Have been with Plusnet approx 12 months. All fine until last couple of months.
Factory reset done , channels changed etc.
Works short while then back to square one.
Message 1 of 3
(220 Views)
2 REPLIES 2
Re: WiFi constantly dropping
20-03-2020 11:00 AM
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Message 2 of 3
(199 Views)
27-03-2020 10:10 AM
Welcome to the forums.
I'd have a look at https://www.plus.net/help/broadband/getting-the-best-wifi-signal/ for some ideas.
It's also worth splitting the frequency between 2.4ghz and 5ghz as this helps a lot of people. If you have problems, we can look to do that remotely for you.
Message 3 of 3
(125 Views)
