WiFi constantly dropping
Ozzy2019
Not sure how to fix.
WiFi constantly dropping.
Have been with Plusnet approx 12 months. All fine until last couple of months.
Factory reset done , channels changed etc.
Works short while then back to square one.
2 REPLIES 2
Strat
Fixes: 519
Re: WiFi constantly dropping
Moderators Note
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 93.0 (64-bit)
plusnettony
Fixes: 18
Welcome to the forums.
I'd have a look at https://www.plus.net/help/broadband/getting-the-best-wifi-signal/ for some ideas.
It's also worth splitting the frequency between 2.4ghz and 5ghz as this helps a lot of people. If you have problems, we can look to do that remotely for you.
 Tony T
