WiFi calling
RealAleMadrid
Fixes: 68
Re: WiFi calling
@bertmay  If that is the case it would appear that your phone is not supported by giffgaff, as @Protech suggested in msg#8 Motorola devices my not be supported. Can you get it to work on other wi-fi networks such as a friend's or a public network?
bertmay
Re: WiFi calling
Thanks to you all for the advice, it's all a bit beyond me i afraid.
My contract ends in March & we will want to continue having a home phone. Looks like the wired landline phone will go.
The offer of an EE fibre & a phone from them,
Do I get an EE router for the set up
Bert
bertmay
Re: WiFi calling
The phone indicates it is making a wifi call by the displayed symbols on the screen when calling our other phone.
so for the moment I will leave it off
Bert
bertmay
Re: WiFi calling
I also went into the router Hub1, advanced settings, firewall, configuration, changed from default to disabled, not sure if that was a good idea or not.
Fixes: 585
Re: WiFi calling
Its NOT a good idea and will make no difference to whether wifi calling works or not!
Fixes: 251
Re: WiFi calling
There’s another Giffgaff user around here having issues with WiFi calling … perhaps there’s a mobile provider issue which their customer support team can assist with?
Protech
Seasoned Pro
Fixes: 8
Re: WiFi calling
This link includes the Giffgaff list of supported phones for WiFi calling , others may or may not work YMMV.
https://help.giffgaff.com/en/articles/258841-what-is-wifi-calling-and-volte
You can check out but you can never leave ( easily)
mwwagain
Fixes: 4
Re: WiFi calling
Bert
EE send a router which has a green socket that they tell you 'Just plug your old phone in'.
Whether it actually works or not is a different issue.  My experience is 0 from 2.
I would consider a stand-alone VOIP setup, which you can get going now with a throwaway number.  Then you are not tied to the limited choice of expensive legacy suppliers.
When you __HAVE BEEN__ switched to FTTP you then have 30 days in which to put your old phone number over to the VOIP supplier
