WiFi Auth Issues
matthewmartin
WiFi Auth Issues
Plusnet Hub Two
v0.10.00.04201-PN
Last firmware update: 29-Jun-2023
Symptom:
2.4GHz gives authentication error despite password being correct
5GHz band not broadcasting
I've power cycled, reset to default, individually tested both 2.4 and 5 in isolation, changed passwords, changed channels, changed modes, changed keys, changed ssid. Therw is definitely an issue with authentication, as every device fails to connect with auth issues and if i disable WPA I can connect fine on 2.5GHz. The 5GHz radio seems completely canned. What are my options, other than trying to find another old router lying about i can use an an AP?
7 REPLIES 7
Fixes: 479
Re: WiFi Auth Issues
Moderator's note:
Post released from the automatic Spam Filter.
Fixes: 387
@matthewmartin Has this always been the case?
matthewmartin
@jab1 Nah hasn't always been the case, all devices got booted off this morning about half 6, spoke to a guy on the phone and went through all the usual checks and we've come to the conclusion it's an issue with the router itself so he's sending a new one out.
Fixes: 387
@matthewmartin OK - let us know if it solves it.
matthewmartin
@jab1
Just got home from work and set up the new hub, seems to have worked!
Fixes: 387
OK, @matthewmartin  - sounds like it was a dodgy Hub - glad it has worked.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
