Wi fi speed
- My Router
- Wi fi speed
Wi fi speed
31-10-2017 2:51 PM
Wi Fi Speed
Hi
Some help would be appreciated. I have just recently signed up for faster broadband but cannot get more than 10 Mb. on my computer
If i use a ethernet hard wire cable from my hub1 router to my computer I get 36 Mb
If I remove the ethernet cable and just use wifi I get 10 Mb.
By the way' my router is about 2 metres away from my computer.
Using wifi on my laptop next to my computer i am getting 38 Mb.
If I move the laptop to my living room ( about 5 or 6 meters away ) wifi speed is still 38 Mb.
I have gone into Avanced settings and tried diferent chanels (I admit,not all of them yet) but dont seem to get more than 11 Mb.
Any other tips could you recommend.
Re: Wi fi speed
31-10-2017 3:03 PM
Plus nets speeds are useless. I have nothing but problems from the moment it arrived. Im just counting down the days till my contract runs out... suggest you do the same
Re: Wi fi speed
31-10-2017 3:16 PM - edited 31-10-2017 3:17 PM
If you have a speed issue then post in a decent manner asking for help or raise it as a fault instead of giving it mouth about a problem the Plusnet staff won't anything about until you've posted the problem. You will find the staff (and other members) very helpful if you post in a positive manner.
What speed fibre did you sign up for? 38/2 (shortly to be 38/10) or the 80/20?
Growing old is inevitable...But growing up is optional.
Re: Wi fi speed
31-10-2017 5:25 PM - edited 31-10-2017 5:39 PM
What type of WiFi adapter do you have in your Desktop computer? Sounds like this could be the issue (since you can get much faster speed with a different PC if I understand it).
Re: Wi fi speed
31-10-2017 8:46 PM
Thanks for reply,
I suspected it at first that the problem could be my compter.I don't know what type of adaptor is in my computer. And to be honest I don't nkow how to find out. would i be able to get a dongle and use that for a wifi signal.
Re: Wi fi speed
01-11-2017 1:50 AM
Go to device manager -> Network Adapters -> open the properties on your wifi adapter.
Look at the 802.11 versions (a/b/n) which are supported. at 10mbps I suspect that it is 'a' only.
Yes you could get a wifi dongle, but if the router is near your PC, what's the problem remaining connected via an Ethernet cable? It will always perform better than wifi.
Re: Wi fi speed
01-11-2017 8:27 AM - edited 01-11-2017 8:27 AM
....and a +1 to Townman's reply. Where possible I always use Ethernet connections rather than WiFi, faster and more reliable all around in my experience.
Re: Wi fi speed
01-11-2017 8:39 AM
Thanks, will give it a try
Re: Wi fi speed
01-11-2017 8:51 AM
The router is located in a hallway. My computer is located about 2 metres away and the cable crosses the hallway. Sods law that one of the inhabitants of this household will trip over it. Cannot re-locate the router either.. But I get your drift about using the ethernet cable. But it's one of those situations where it's bugging me and I have got to fix it.
But once again i appreciate the time you take to reply .
Re: Wi fi speed
01-11-2017 9:17 AM
I have got as far as Network Adapters and clicked on it.It brings up the name of the Adapter. ( Qualcom Atheros )but nothing resembling 802.11
Re: Wi fi speed
01-11-2017 10:31 AM
Some adapters indicate their spec in their names ... for others you need to inspect the detailed properties.
Re: Wi fi speed
01-11-2017 11:16 AM
Did you right click on the adaptor and go to properties? It should bring up more details than just the name.
Re: Wi fi speed
01-11-2017 11:38 AM
Qualcom Atheros AR500 7EG
Under that it gives details of Realtec ethernet
below that again it gives a list of Wan miniports
Re: Wi fi speed
01-11-2017 12:34 PM
Have you tried updating the driver? This has been known to fix a few problems.
Re: Wi fi speed
01-11-2017 4:39 PM
Never thought of that. Will give it a try
