Wi fi router
DDave
Wi fi router
Have a plusnet hub 2 router which i want to swap out for my hub 1 is there a simple way i can keep my existing wifi password only have iphone, ipad no computer
5 REPLIES 5
Fixes: 1,495
Re: Wi fi router
Moderators Note
This topic has been moved from Broadband to My Router
Re: Wi fi router
@DDave
In the first instance you will have to connect to the Hub Two wifi.
Then navigate from the Hub Two home page  http://192.168.1.254 >Advanced Settings >Wireless
There you will find the wireless setting for Network name and security Password
NOTE: it is not possible to split the 2.4 and 5 GHz wireless names
HTH
DDave
Re: Wi fi router
Not computer savvy Dan when i enter that number in my search engine comes back with nothing
Fixes: 387
Re: Wi fi router
@DDave you enter that number in the search bar at the top of your screen or, even easier, just click on it - it should take you straight there.
DDave
Re: Wi fi router
All sorted now thanks everyone, recently changed to fibre only not FF broadband and speed only 47mbps on 2.4ghz rather than keep changing channels on my (Hub 1) I already had a Hub 2 router I had never used which i know doesn't seperate both channels so mobiles and tv wifi are connecting at 5ghz--73 mbps
