When will the the Hub One 5Ghz Wireless Firmware upgrade(289) be deployed?
- My Router
- When will the the Hub One 5Ghz Wireless Firmware u...
02-03-2021 4:13 PM
Raised a ticket today (211951221)
In the past 3/4 weeks I am having a problem every single day. Discovered by visiting the forum that there is a fix available . However there is no firm date. I have currently switched 5ghz off , but would obviously prefer if it wasn't!
I understand @bobpullen knows all about the issue. 😀
So can I either have a firm date for the next week or so , alternatively the update downloaded to my router ASAP.
Many Thanks
Re: When will the the Hub One 5Ghz Wireless Firmware upgrade(289) be deployed?
02-03-2021 4:36 PM
This topic has been moved from ADSL Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 102.0 (64-bit (64-bit)
09-03-2021 2:58 PM
As I have heard nothing in over a week .
Can you please put this into the TOPIC
Hub One - 5GHz WiFi issue
As it appears this topic is being reviewed.
09-03-2021 4:15 PM
When you have given up and want a far better hub anyway then Smarthub 6s are currently going for peanuts on Ebay. Follow links in this post for setting instructions https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
- My Router
