What to do with redundant Plusnet router
scuda1
Getting stuff for recycling, I came across the router that Plusnet supplied, when I joined many many years ago. It is a Technicolor TG582n, and has been sat in a cupboard, unused for a long time.
Could someone from Plusnet tell me if I need to return it to Plusnet, or can I dispose via local recycling?
If Plusnet want it back, who to, and how do I send?
scuda
2 REPLIES 2
Fixes: 585
Re: What to do with redundant Plusnet router
@scuda1 well you don't need to return it
If you still have the packaging (doubtful!) You can try using https://www.plus.net/help/broadband/returns/ but a TG582 might be too old to be recognised by that process,
Otherwise use local recycling
scuda1
@MisterW
Thanks, I've printed out a return label and will send it to Plusnet.
Thanks for your help
scuda
