What router is supplied to new customers these days?
Malcky
Hi folks,
My other half's sister is getting fibre plusnet installed/activated on the 17/1/19 into her new house and she has asked me to set her network up.
So, what router is being issued these days to new customers?
And can I do the following on said supplied router:
1: Can I disable the wifi on the router?    (I plan on installing seperate wifi access points for better/full house coverage)
2: Can I chose which DNS servers are used?  (I want to use the like of google's DNS addresses -  8.8.8.8 & 8.8.4.4)
3: Are the LAN ports of the router gigabit speed ports?
8 REPLIES 8
Fixes: 1,600
Re: What router is supplied to new customers these days?
Hi @Malcky
The Hub Zero (Sagemcom 2704N) for ADSL, or the Hub One for FTTC.
Yep.
Not for the Hub One I'm afraid, but you can do for the Hub Zero.
Unfortunately not, I believe they're 100MB/s.
[edit]
I see you've said she's getting fibre, I've crossed out some points I've made as they refer to ADSL.
Browni
Aspiring Hero
Fixes: 60
@Gandalf fyi, The Hub One has gigabit LAN ports.
Fixes: 1,600
I stand corrected. Thanks for the heads up.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
Malcky
Thanks for all the speedy answers folks.
2 out of 3 aint bad I guess.
Malcky
My friend has had her internet all sorted out, but I was wanting to set up a ping monitor too, but it seems that the supplied router does not accept the pings.....they just drop instantly.....how can I get the router to accept pings from thinkbroadband.com website?
Mustrum
Fixes: 77
@Malcky You can't, te Hub One does not have an option to respond to pings.
However you may have something on your network that responds to pings that you could put in the DMZ - I used my  Blu Ray player on the grounds that although it was "pingable" it was a device that could not be logged into and therefore maybe compromised.
Browni
Aspiring Hero
Fixes: 60
The Hub One won't respond to pings unfortunately.
A workaround is to connect via LAN a device that will respond to pings and put that in the Hub One's DMZ but that has obvious security issues.
I personally used a Now TV Box.
eta: beat by seconds Grin
