What is the most up to date firmware......
matteastick75
Please help me..
 My router is playing up and i have to keep resetting it, i go from 35mb to 5mb in a day.
My router hasnt been updated since Feb 19..
Plusnet Hub One | Software version 4.7.5.1.83.8.263 | Last updated 09/02/19
Do i need a update or what....
Matt
5 REPLIES 5
mort7890
Fixes: 4
Re: What is the most up to date firmware......
Latest update is Plusnet Hub One | Software version 4.7.5.1.83.8.263 | although mine shows Last updated 19/07/17
Tibzor
Fixes: 25
Hi @matteastick75
Sorry to hear about problems with your broadband. Connection is stable with correct speeds. Issues you are experiencing are most likely down to wireless network performance.
Please check out the help and support page here https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193 Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
bobpullen
Fixes: 289
That 29 day uninterrupted connection doesn't look like the router is being reset? 🤔
matteastick75
the router not being reset, is that a problem..?
Is it supposed to happen automatically ..?
bobpullen
Fixes: 289
Not sure what you're asking?
You stated that you had to keep resetting the router, yet an image was posted suggesting it had been up for almost a month without any sign of it being reset?
