Watchdog reset 0x3 hardware fault
- My Router
- Watchdog reset 0x3 hardware fault
23-09-2020 8:56 AM
Hello. I appear to have a similar Hub One hardware fault as others have raised here, referred to as 'watchdog reset: cause 0x3', which forces a reboot at random times. I raised this over a year ago with Plusnet support, but was asked to monitor it. Having viewed the logs recently, it is now clearly proven to be a recurring problem so I would like Plusnet to address this asap please (I assume Plusnet read these forums) by confirming the issue and swapping out the faulty hardware. Recent logs are below to show the extent. Many thanks in advance for your help.
06:13:05, 03 Sep. | ( 31.210000) System up, firmware version: 4.7.5.1.83.8.263 |
06:12:51, 03 Sep. | ( 17.790000) System start |
08:05:55, 02 Sep. | ( 31.130000) System up, firmware version: 4.7.5.1.83.8.263 |
08:05:41, 02 Sep. | ( 17.740000) System start |
23:50:49, 25 Aug. | ( 31.290000) System up, firmware version: 4.7.5.1.83.8.263 |
23:50:35, 25 Aug. | ( 18.010000) System start |
20:47:37, 14 Aug. | ( 31.250000) System up, firmware version: 4.7.5.1.83.8.263 |
20:47:23, 14 Aug. | ( 17.890000) System start |
20:47:23, 14 Aug. | ( 17.890000) Boot reason: watchdog reset (cause: 0x3) |
22:00:05, 02 Aug. | ( 31.170000) System up, firmware version: 4.7.5.1.83.8.263 |
21:59:51, 02 Aug. | ( 17.830000) System start |
21:59:51, 02 Aug. | ( 17.830000) Boot reason: watchdog reset (cause: 0x3) |
19:19:47, 27 Jul. | ( 31.740000) System up, firmware version: 4.7.5.1.83.8.263 |
19:19:33, 27 Jul. | ( 18.110000) System start |
19:19:33, 27 Jul. | ( 18.110000) Boot reason: watchdog reset (cause: 0x3) |
10:04:23, 18 Jul. | ( 31.090000) System up, firmware version: 4.7.5.1.83.8.263 |
10:04:09, 18 Jul. | ( 17.630000) System start |
10:04:09, 18 Jul. | ( 17.630000) Boot reason: watchdog reset (cause: 0x3) |
22:25:59, 16 Jul. | ( 30.590000) System up, firmware version: 4.7.5.1.83.8.263 |
22:25:46, 16 Jul. | ( 17.540000) System start |
22:25:46, 16 Jul. | ( 17.530000) Boot reason: watchdog reset (cause: 0x3) |
17:41:56, 15 Jun. | ( 30.520000) System up, firmware version: 4.7.5.1.83.8.263 |
17:41:43, 15 Jun. | ( 17.880000) System start |
17:41:43, 15 Jun. | ( 17.880000) Boot reason: watchdog reset (cause: 0x3) |
07:37:52, 01 Jun. | ( 31.130000) System up, firmware version: 4.7.5.1.83.8.263 |
07:37:38, 01 Jun. | ( 17.450000) System start |
07:37:38, 01 Jun. | ( 17.450000) Boot reason: watchdog reset (cause: 0x3) |
08:34:09, 09 Mar. | ( 31.660000) System up, firmware version: 4.7.5.1.83.8.263 |
08:33:55, 09 Mar. | ( 18.040000) System start |
08:33:55, 09 Mar. | ( 18.040000) Boot reason: watchdog reset (cause: 0x3) |
13:53:59, 08 Mar. | ( 31.230000) System up, firmware version: 4.7.5.1.83.8.263 |
13:53:45, 08 Mar. | ( 17.460000) System start |
13:53:45, 08 Mar. | ( 17.460000) Boot reason: watchdog reset (cause: 0x3) |
02:34:29, 04 Mar. | ( 31.800000) System up, firmware version: 4.7.5.1.83.8.263 |
02:34:15, 04 Mar. | ( 17.850000) System start |
02:34:15, 04 Mar. | ( 17.850000) Boot reason: watchdog reset (cause: 0x3) |
07:24:44, 06 Dec. | ( 31.210000) System up, firmware version: 4.7.5.1.83.8.263 |
07:24:30, 06 Dec. | ( 17.510000) System start |
07:24:30, 06 Dec. | ( 17.510000) Boot reason: watchdog reset (cause: 0x3) |
08:12:55, 05 Nov. | ( 31.310000) System up, firmware version: 4.7.5.1.83.8.263 |
08:12:41, 05 Nov. | ( 17.350000) System start |
08:12:41, 05 Nov. | ( 17.350000) Boot reason: watchdog reset (cause: 0x3) |
04:34:59, 05 Nov. | ( 31.440000) System up, firmware version: 4.7.5.1.83.8.263 |
04:34:45, 05 Nov. | ( 17.640000) System start |
04:34:45, 05 Nov. | ( 17.640000) Boot reason: watchdog reset (cause: 0x3) |
12:24:29, 31 Aug. | ( 31.350000) System up, firmware version: 4.7.5.1.83.8.263 |
12:24:15, 31 Aug. | ( 17.550000) System start |
12:24:15, 31 Aug. | ( 17.550000) Boot reason: watchdog reset (cause: 0x3) |
01:30:51, 31 Aug. | ( 31.530000) System up, firmware version: 4.7.5.1.83.8.263 |
01:30:37, 31 Aug. | ( 17.590000) System start |
01:30:37, 31 Aug. | ( 17.590000) Boot reason: watchdog reset (cause: 0x3) |
17:29:12, 26 Aug. | ( 31.980000) System up, firmware version: 4.7.5.1.83.8.263 |
17:28:58, 26 Aug. | ( 17.850000) System start |
06:08:52, 04 Aug. | ( 30.930000) System up, firmware version: 4.7.5.1.83.8.263 |
06:08:38, 04 Aug. | ( 17.290000) System start |
06:08:38, 04 Aug. | ( 17.290000) Boot reason: watchdog reset (cause: 0x3) |
Re: Watchdog reset 0x3 hardware fault
25-09-2020 7:01 PM
Hi @silversurf, I'm sorry to hear you've been affected by this issue. I've posted a new router out to you this evening and raised a support ticket regarding this on your account. I tried to call but I must have missed you, I'll try and get in touch again on Monday.
- My Router
