Vigor 120 ISP info
- My Router
- Vigor 120 ISP info
Vigor 120 ISP info
26-07-2018 8:40 PM
I realize this is an obsolete product, but maybe you can tell what I am doing wrong.
I just bought the Annex A modem V2, and updated its firmware to version 3.7.2
However, when I enter the "PPPoE / PPPoA Client Mode" screen, I don't see the area "ISP Access Setup" on the right hand side. Instead, I see "MAC address Setting" like in picture. In addition, the "PPPoE Pass-through" button can't be unchecked. Lastly, I reset the modem (through pin).
Please advise how to enter my ISP info, as I will be hooking the vigor 120 to a dd-wrt modem, and I just want the vigor to get a WAN IP from ISP.
Thanks.
Re: Vigor 120 ISP info
26-07-2018 10:14 PM
I freely admit to knowing nothing about this modem but a quick search tells me that it is an ADSL device. As I see that you are posting this on the Fibre board I can only assume that you either posted on the wrong board or you're wasting your time trying to get it to work.
27-07-2018 7:28 AM
Like @Baldrick1 I'm not familiar with the unit but AFAIK it's just a modem. You will need to connect it to a router configure the PPPoE connection on the router.
27-07-2018 12:54 PM
Moderator's note by Dick (Strat): Topic moved to a more appropriate board.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
