VR900
- My Router
- VR900
VR900
23-04-2018 12:31 PM
Re: VR900
23-04-2018 3:01 PM
As long as you have these basics right it should connect up just fine:
Broadband username or login name | yourusername@plusdsl.net |
Connection type or encapsulation | 'PPPoA' or 'PPP over ATM' |
Password | The password you use to log in to the Member Centre |
Virtual Path Identifier (VPI) | 0 |
Virtual Channel Identifier (VCI) | 38 |
Multiplexing method |
'VC Based' or 'VCMUX' or 'VC-Multiplexing' |
I'd try a factory reset if you've got all that set right but still can't connect with it.
Re: VR900
23-04-2018 3:06 PM
Re: VR900
23-04-2018 3:33 PM
I'll stick with the hubone for now, seems to be doing a better job than my old plusnet router did anyway.
Since you've got a hub one I assume you're on a Fibre(FTTC) connection. @adamwalker 's settings are for ADSL . You need to select PlusNet_VDSL from the ISP list in the connection settings and then enter your username and password as in Adam's settings
Re: VR900
23-04-2018 3:38 PM
