VPN issues with my current ISP. Router specification
- My Router
- VPN issues with my current ISP. Router specificati...
03-08-2020 1:54 PM
As you can see from my account I am changing to you very soon. I expect to receive the router soon and I have been trying to call you but it is impossible to talk to you on the phone..why? Please see below.
At the moment my ISP is Talk Talk. The reasons for leaving them, apart from the connection discconecting too often, and poor customer service, I am having VPN problems when connecting to GlobalConnect with my work-laptop. I want you to be aware of this so you can send me the right better router from the beggining to ensure I dont have these problems.Please let me know.
Many thanks
Regards
Re: VPN issues with my current ISP. Router specification
03-08-2020 1:59 PM - edited 03-08-2020 2:01 PM
Duplicate posts removed. Please keep your issue to one thread. It makes it easier for staff to deal with it.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
03-08-2020 2:04 PM
Apologies for that. I did not know where to best place it. Hopefully here will get the better answer.
Thank you
Regards
06-08-2020 11:35 AM
Hi @besugi - welcome to the forums.
Although we don't troubleshoot VPN software issues ourselves, you can still use the VPN software through the Hub One router. If your work laptop (and the VPN software) is provided by your IT department for example, they would be able to make sure everything's set correctly for the laptop and the VPN software. If you do encounter issues in the future you can always get back to us here and we'll point you in the right direction.
- My Router
