VPN hub one
masive39
VPN hub one
hello everyone I've just changed over from DSL to Fibre and the question is would it be possible to add a VPN onto my router and when I'm running anything wirelessly I don't get a wireless light on the router is that normal .{ my router is a PlusNet one hub ? }
1 REPLY 1
bill888
Champion
Fixes: 36
Re: VPN hub one
It is not possible to add a VPN client or server onto the Hub One.  If you wish to subscribe to a VPN service, you will either have to install VPN client app on your devices(s), or add another router which does support VPN if you also wish to retain the Hub One for non-VPN internet access.
If wifi is enabled on the Hub One, the corresponding wireless light should be lit up.  Perhaps the wifi LED is defective on your hub?
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
