VPN for my plusnet router.
- My Router
- VPN for my plusnet router.
22-01-2021 12:19 PM
Hi. Can I set up Surfshark directly onto my plusnet router.?
thanks
DW
Re: VPN for my plusnet router.
22-01-2021 12:40 PM
Nope
22-01-2021 1:01 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
22-01-2021 7:52 PM
fwiw, Surfshark still supports insecure L2TP protocol, so in theory, any off the shelf cable router (without modem) should work.
Here are L2TP instructions for ExpressVPN and TPlink router for example:
https://www.expressvpn.com/support/vpn-setup/manual-config-for-tp-link-router-with-l2tp/
Just plug the vpn router into existing ISP facing wifi router.
If you want to use more secure protocols like OpenVPN, you will need a more expensive/powerful router.
eg. a used Linksys EA6350 v3 with quad core ARM processor can manage 25 mbps openvpn speeds with OpenWRT. Asus RT-AC86u can do 70+ mbps openvpn speeds with stock AsusWRT firmware.
22-01-2021 11:39 PM
