VPN for my plusnet router.
Lupo
Hi. Can I set up Surfshark directly onto my plusnet router.?
thanks
DW
4 REPLIES 4
Fixes: 393
Re: VPN for my plusnet router.
Nope
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
bill888
Champion
Fixes: 38
fwiw, Surfshark still supports insecure L2TP protocol, so in theory, any off the shelf cable router (without modem) should work.
https://support.surfshark.com/hc/en-us/articles/360010324739-What-protocols-can-I-use-with-Surfshark...
Here are L2TP instructions for ExpressVPN and TPlink router for example:
https://www.expressvpn.com/support/vpn-setup/manual-config-for-tp-link-router-with-l2tp/
Just plug the vpn router into existing ISP facing wifi router.
If you want to use more secure protocols like OpenVPN, you will need a more expensive/powerful router.
eg.  a used Linksys EA6350 v3 with quad core ARM processor can manage 25 mbps openvpn speeds with OpenWRT.  Asus RT-AC86u can do 70+ mbps openvpn speeds with stock AsusWRT firmware.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
dafyddapw
Many thanks fir the advice- much appreciated.
