Using a second router as a repeater
adriang
Hi All
I had this working before where I have my plusnet router downstairs plugged into master socket. I then had a powerline adapter in one of the LAN ports which is received by a TP Link router in its WAN port. I then was able to config the TP link by following a guide online on how to do it - https://www.techadvisor.co.uk/how-to/network-wifi/router-repeater-3633135/
However I recently signed up to Fibre and got a new router which also has a WAN port.
1. Should the powerline adapter go into the WAN port of the plusnet router also? Or keep it in the yellow LAN port?
2. Is there a better way to set this up than what I have described above?
1 REPLY 1
Fixes: 401
Re: Using a second router as a repeater
The Poweline device should be plugged into one of the LAN ports on the Hub One. If the TP link works as a WAP for you then keep it as it is.
