Using a Shell Broadband Router
Bort
Can I use my previous supplier's router (Shell Broadband) for use with PlusNet given my new router has still not arrived?
5 REPLIES 5
Fixes: 582
Re: Using a Shell Broadband Router
If the Shell router allows you to change the PPPoE username and password then possibly.
See this https://www.plus.net/help/broadband/broadband-connection-settings/ for details on the information you need to set
Gel
Champion
Fixes: 29
Try the settings provided by PN; however, it depends whether the unspecified make of router is locked down to their network, as is one en route to you.
Fixes: 1,495
Seems to be a Technicolor DWA0120 router - not sure if the firmware is locked down, but they allow you to use your own router so there is hope.
ckcomputing
@Bort
Shell used to provide a Technicolor TG588V V2 to their customers; current customers are supplied with a Technicolor DWA0120 as mentioned by @dvorak.
You need to check which router you were supplied with.
Professionals are predictable - it's the amateurs that are dangerous!
Bort
Thanks everyone for their input but it transpires that “due to a system error” my phone line activated last night, my old broadband supplier was cut but the PlusNet broadband will not go live any sooner than Wednesday 7th April so amending my current router settings would not work as there is absolutely zero internet feed coming to my property for the next week.
In fairness to PlusNet they have committed to covering the cost(s) of any alternative data supply I can obtain so I am now searching for the quickest suitable option... not easy when the shops are shut!
