Using BT wifi extender with Plusnet
ronecc
Since switching to Plusnet from BT, my Samsung smart tv, in the bedroom keeps buffering. I have a BT 1200 wifi extender I do not use. Does anybody know whether it can be made to work with Plusnet. My laptop will find the extender, but will not connect as it requires the old BT password.
3 REPLIES 3
LifeonMars
Seasoned Pro
Fixes: 12
Re: Using BT wifi extender with Plusnet
It should work,
see
https://shop.bt.com/content/uni2/documentation/b15p/11ac_dual-band_wi-fi_extender_1200_user_guide.pd...
and reset to factory settings if forgotten password.
ronecc
Thanks for the info, I will give it a try.
ronecc
Fixed it, thanks
