Using BT wifi extender with Plusnet
FIXED- Subscribe to RSS Feed
- My Router
- Using BT wifi extender with Plusnet
04-03-2019 1:30 PM
Since switching to Plusnet from BT, my Samsung smart tv, in the bedroom keeps buffering. I have a BT 1200 wifi extender I do not use. Does anybody know whether it can be made to work with Plusnet. My laptop will find the extender, but will not connect as it requires the old BT password.
Fixed! Go to the fix.
04-03-2019 2:05 PM - edited 04-03-2019 2:07 PM
It should work,
see
and reset to factory settings if forgotten password.
Re: Using BT wifi extender with Plusnet
04-03-2019 2:08 PM
Thanks for the info, I will give it a try.
04-03-2019 2:31 PM
Fixed it, thanks
- My Router
