Using BT Smart Hub 2 with Plusnet
grajay155
Waiting to join Plusnet and want to use my Smart Hub 2 but looking at the posts which assure me that I can I find theat when I access my Smart Hub Manager I find that there is no way to change the Broadband Username (nor for that matter is there anywhere to enter a password.   Am I missing something please?  Thanks
3 REPLIES 3
Fixes: 480
Re: Using BT Smart Hub 2 with Plusnet
@grajay155  Welcome to the forum.
All that you have to do is unplug the DSL cable, delete the BT default username and add your Plusnet username followed by @plusdsl.net and password before reconnecting the DSL cable. See also here. https://community.plus.net/t5/My-Router/Using-A-BT-Smarthub-An-Update/m-p/1795292#M24601
grajay155
Thanks for the welcome.
Brilliant advice too - very many thanks for your help.
Fixes: 1,495
Moderators Note
This topic has been moved from Fibre to My Router
