Use a USB drive on Hub One with Apple OS X El Capitan 10.11.6
trevorlawson
When I plug my OS X Extended (Journaled) formatted USB drive into the Hub One USB port, the hub manager recognises an External USB 3.0 (Rev: 0) device, but says File type not supported. How can I set up a recognised USB drive on the Hub One USB port so that it's accessible through the Finder on my hardwired Mac Pro? Thanks for any detailed, practical suggestions.
2 REPLIES 2
Browni
Aspiring Hero
Fixes: 49
Re: Use a USB drive on Hub One with Apple OS X El Capitan 10.11.6
Format the Drive as FAT16, FAT32 or NTFS.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
trevorlawson
Unfortunately that won't work for me - I need the drive to be an Apple Extended format for use as a Time Machine backup. Maybe I need to look at a more compatible wifi router than the Hub One.
