Updating firmware on Hub One- router has been in storage (version 4.7.5.1.83.8.237.2.2)
FIXED- Subscribe to RSS Feed
- My Router
- Updating firmware on Hub One- router has been in s...
08-08-2020 9:10 AM
Hi there
Is there any chance a friendly mod could push a firmware update out to my router? I had been using my own since the beginning but it stopped working yesterday and so I have pushed the Plusnet supplied one into action (it is working fine btw!)
Many thanks
Matt
Fixed! Go to the fix.
Re: Updating firmware on Hub One- router has been in storage (version 4.7.5.1.83.8.237.2.2)
09-08-2020 11:46 AM
If the router has been in storage for some time (looking at the firmware it probably has) then it will more than likely not be registered for an update. However @bobpullen might be the route to take, he usually fixes these problems.
09-08-2020 2:36 PM
Hi there
Thanks for this- the wifi on the plus net router was really patchy, so I thought I would try a bt smart hub that I had knocking around from before we moved (and had also never used!) The wifi coverage seems better with this, but my guess is that this also needs a firmware update too now! I'm sure that there will be a way- maybe they will auto update?
Thanks again.
09-08-2020 8:06 PM
They often update their firmware when you first connect them. If you leave it then it should automatically update.
- My Router
