Unknown device
- My Router
- Re: Unknown device
Unknown device
12-04-2020 1:52 PM
Tidying things up a bit and noticed a few unknown devices connected to my network. Identified all but one
called "DESKTOP-7BS5LHE" . So I applied permanent access control to it to cut off it's internet connection (the
router doesn't seem to have an option to restrict wireless to individual devices ) and it is no longer connected
and only shows up in the Access Control Panel.
Am I correct in assuming this device is coming from out side and therefore a possible hacker !!!
Nige
Re: Unknown device
12-04-2020 3:49 PM - edited 12-04-2020 3:50 PM
@Nige90 Welcome to the forum.
You shouldn't assume anything. I suspect that this is a Windows PC. Do you have one in the house? Very often you can have two connections to a device, one wireless and another Ethernet even though only one is in use. It will not be a potential hacker, it's either a real hacker within the wireless range of your router who has cracked your wireless password and has access to your network or something in your house.
If you want to be sure then change your wireless password in the wireless advanced settings.
Re: Unknown device
12-04-2020 5:49 PM
Hi Baldrick,
Already changed password.
Running an iMac and Windows laptop.
I do have a Linux based music server that is both wireless and Lan, so possibly that. Don't ever recall setting the name as
the device in question though.
Re: Unknown device
12-04-2020 6:34 PM
Solved....Forgot the telly in the bedroom.....muppet 🙄
Re: Unknown device
12-04-2020 10:49 PM
Confession is good for the soul. 😃
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Unknown device
13-04-2020 9:04 AM
Been there and done that! In my case it was an old Kindle that had not been used for ages.
