Unable to join network
Rustybob
Help, Sagem 2704n, devices continue to get “unable to join network”. I’ve had many routers over the years and never had this problem, looks like the router can not support many devices ? How can this be? Can it be fixed
2 REPLIES 2
OskarPapa
Fixes: 64
Re: Unable to join network
Hi @Rustybob ,
Thanks for your post and welcome to our Community.
In regards to the issue you are seeing one thing I'd suggest to do is factory reset the router.
This can be done by pressing a pin, cocktail stick etc.. into the "reset hole on the back of the router for 5-15 seconds. You should see the router reboot and then within a few minutes hopefully this may have resolved the issue you're seeing.
Please let us know how it goes and if you do have any further issues don't hesitate to get back in touch.
Rustybob
See post device limit - they have exactly the same problem
