Unable to View CCTV Remotely
ohilveti9
My friend switched to Plusnet 3 days ago from BT. I setup his router for port forwarding for his CCTV setup exactly same as with the BT router. He now has a very strange issue that he cannot view his CCTV remotely while on 4G with o2, I tested with my Three mobile and also a Vodafone one and this works absolutely fine. We then tried another mobile that was on o2 and the same issue occurred. This used to work flawlessly while with BT. Anybody else experienced this or any ideas?!?
1 REPLY 1
Fixes: 390
Re: Unable to View CCTV Remotely
@ohilveti9
Put his BT hub back.
Remove the DSL cable..
Log into the hub and go to the Advanced/Broadband page.
Change the username to Plusnet account username@plusdsl.net
Change password to Plusnet account password.
Select save if there's the option else just plug the DSL cable back in.
That should fix the problem.
The BTSmarthub 6 is a better hub than Plusnet's and many of us use them. For the full setting instructions see. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
