Ubiquity Edge Router
- My Router
- Ubiquity Edge Router
on
10-12-2020
8:53 AM
- last edited on
10-12-2020
9:32 AM
by
Quick question, I won’t complicate it , I have an ubiquity edge router coming today , I currently have a bt business hub , will I be able to use the bt business hub as a modem mode only paired with the edge router ( bt business hubs do have this option as opposed to the residential version) or will I have to buy a separate modem like a draytek vigor 130 , thank you.
Moderators Note: All caps title removed as per Forum rules
Re: UBIQUITY EDGE ROUTER
10-12-2020 9:13 AM
I believe so but I've not used one myself. This thread should help https://community.plus.net/t5/My-Router/BT-smart-hub-hidden-bridge-mode-menu/td-p/1768691
10-12-2020 9:31 AM
Moderators Note
This topic has been moved from Fibre to My Router
