Ubiquiti AP Lite & HubOne setup advice
- My Router
- Ubiquiti AP Lite & HubOne setup advice
07-01-2020 2:46 PM
Hi All,
I currently have a HubOne. I am in the process of installing a home network and wanting to use the Ubiquiti Lite access point (https://www.ui.com/unifi/unifi-ap-ac-lite/)
As part of my initial setup I am hoping to setup as follows:
- Disable wifi on the HubOne
- Connecting a POE switch to the WAN port of the HubOne
- Connecting the access points to the POE switch
I have been looking into getting a separate router & modem but currently unsure as to why I would need to do this in the interim?
Your advice would be great!
Re: Ubiquiti AP Lite & HubOne setup advice
07-01-2020 3:05 PM
You will need to connect to a LAN port on the Hub One, not the WAN port
07-01-2020 3:10 PM - edited 07-01-2020 3:12 PM
In theory would this setup / approach work? I’m looking at getting a unmanaged switch and setting up the Access Points using a desktop controller.
07-01-2020 3:15 PM
I dont know anything specific about the Ubiquiti Lite access points but if they are typical Wireless AP's then I dont see why your theory wont work
07-01-2020 4:18 PM
- My Router
