Tp-link vr900 set up
howaythelad
Hi how can I set this router plugging it into the socket but not working second one now do I need to manually enter my details apart from username password
7 REPLIES 7
bill888
Champion
Fixes: 36
Re: Tp-link vr900 set up
According to the VR900 emulator
http://static.tp-link.com/resources/simulator/Archer%20VR900(UN)1.0/index.htm
Run 'Quick Setup' and select 'Plusnet_VDSL'.
You will be prompted to enter your PPPoE username and password.
Remember to include your full plusnet username, which is usually in the format:
    myusername@plusdsl.net
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
howaythelad
Still getting connection incorrect username & password I have reset them & still getting the error
howaythelad
But I do have a static IP address
MatthewWheeler
Fixes: 437
We're seeing incorrect password attempts on our end.
Are you using your account password?
 Matthew Wheeler
howaythelad
Hi yes I'm using the same password on my router as I am here I have reset on here today
MatthewWheeler
Fixes: 437
Have you reset your account password or your community password?
 Matthew Wheeler
howaythelad
I reset it for my main account when I logged in & got my connection details
