Tp Link VR400 Ac1200 video problems
- My Router
- Re: Tp Link VR400 Ac1200 video problems
14-10-2019 12:48 AM - edited 14-10-2019 12:51 AM
I think I've set it up correctly following this guide https://community.plus.net/t5/Fibre-Broadband/I-d-like-to-use-my-tplink-1200ac-router/td-p/1558981
Trouble is I'm noticing videos on YouTube, twitter, Facebook play for 4-5 seconds then freeze on my PC and Mobile phone any idea? It's happening almost on every video now
I've separated the Bands, changed the wireless channels off auto etc.
14-10-2019 3:33 PM
Hi @davebetts,
Have you tried to connect your PC to the router with an Ethernet cable to see if that makes a difference?
14-10-2019 8:08 PM
Very frustrating seems to have started almost a month ago when the bt home hub randomly went off and we had to switch back to the PlusNet router, thought it would have improved with the tp link router
15-10-2019 1:21 PM
Hi @davebetts,
Thanks for getting in touch.
I'm sorry to hear of the issues you have had playing video on your TP Link Archer V400 router.
I'm sure this will be down to a setting on the router. Although we can't provide any official support I'm sure the setting will be found in the manual, which you should find here. Please note this has been obtained from a third-party site so I can't vouch for its content.
Thanks - LF
15-10-2019 2:08 PM
15-10-2019 8:07 PM
Thanks for your message @davebetts.
As you've been through all of the usual wireless troubleshooting, the final step is going to be to get into the test socket.
This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Once in the test socket, we'd recommend leaving the connection in it for around 24 hours to see if there's any improvement.
If there's an improvement we can be confident that it's an internal issue.
If not we'd then advise raising the issue over at faults.plus.net
- My Router
