Time within settings incorrect?
- My Router
- Time within settings incorrect?
04-04-2020 6:40 PM
When looking into the 'Access' feature within the settings, it seems the time hasn't changed when the clocks moved forward an hour.
Is there any way I can do this manually or will it have to be at PN's end?
Thanks.
Re: Time within settings incorrect?
04-04-2020 6:56 PM
@Cagney1994 Take a look at this on the Routers board: https://community.plus.net/t5/My-Router/Network-Time-Still-On-GMT/td-p/1719607
04-04-2020 7:25 PM
"I'm afraid all you can do at the moment is adjust the time in the access control to one hour forward, which is a temporary, but effective, measure."
______
How would I do that?
04-04-2020 7:35 PM
Sorry, can't help on your question - I have never had cause to use access control in all my computer days (30+ years), and I also have never seen a Hub router - I still use the TG582N because of its data access. All Hubs are too locked-down and useless for obtaining the kind of information I want.
BTW - the 'one hour forward' should be 'one hour back' - misread the clock.😉
04-04-2020 9:26 PM
04-04-2020 9:32 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
- My Router
