Time within settings incorrect?
Cagney1994
Hi.
When looking into the 'Access' feature within the settings, it seems the time hasn't changed when the clocks moved forward an hour.
Is there any way I can do this manually or will it have to be at PN's end?
Thanks.
5 REPLIES 5
Legend
Fixes: 254
Re: Time within settings incorrect?
Cagney1994
Thanks. And one of your posts in that thread states:
"I'm afraid all you can do at the moment is adjust the time in the access control to one hour forward, which is a temporary, but effective, measure."
______
How would I do that?
Legend
Fixes: 254
Sorry, can't help on your question - I have never had cause to use access control in all my computer days (30+ years), and I also have never seen a Hub router - I still use the TG582N because of its data access. All Hubs are too locked-down and useless for obtaining the kind of information I want.
BTW - the 'one hour forward' should be 'one hour back' - misread the clock.😉
Cagney1994
No worries 😊
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
