Time needs setting on Hub One
UOcUKAkira
I'm trying to use the access settings on my Hub One but the system clock is an hour slow and there's no setting to change it. Is there anything I can do besides having to manually change the timings every time the clocks go back or forwards?
8 REPLIES 8
Legend
Fixes: 219
Re: Time needs setting on Hub One
Welcome to the forums, @UOcUKAkira . Your problem is not unique, it has already been reported and is under investigation, see: https://community.plus.net/t5/My-Router/Network-Time-Still-On-GMT/td-p/1719607
UOcUKAkira
Thanks for the info.
jkgla
Is there any upgrade to this problem.  Our PlusNet Hub One router is still showing GMT + 1 (June 29th 2020) and I can see no way of setting the time manually or requesting the router to reset its time.
Fixes: 390
@jkgla  Welcome to the forum.
I suspect that you have got it the wrong way around. These hubs are stuck on GMT.
jkgla
You are quite right - it’s stuck on GMT.
Owain_2
The BT Home and Business Hub 5 both have the same defect.
jkgla
Sounds pretty incompetent that they haven't fixed a fairly straightforward known fault!
Owain_2
The Home Hub 5 is two versions behind BT's current Smart Hub 2, so it's obsolescent in software terms.
As soon as Wifi 6 drops in price and is supported on more devices, there'll be container-ship-loads of routers headed for a landfill in Africa.
