Time Based Plusnet Access Control, not being removed at end-time on PlusNet Hub One
- My Router
- Re: Time Based Plusnet Access Control, not being r...
23-03-2019 11:23 PM - edited 23-03-2019 11:26 PM
I have recently enabled time based access controls to disable some devices access between 4am to 7am, on
my Plusnet Hub One (Software version 4.7.5.1.83.8.237.2.2). However what I have is that these access control
seem not to be removed when the end-time is reached. Screen shot attached. This router does know the correct time.
Deleteing the access control restored the connectivity,
Is this a known issue ?
Cheers Tony
Re: Time Based Plusnet Access Control, not being removed at end-time on PlusNet Hub One
24-03-2019 12:01 AM
Welcome to the forums @TonyMac
I've never used this feature before, but unitck the permanent - it doesn't mean block it at this time every day, it means a 24 hour daily block.
Then see how you get on
(your firmware is old too, but I wouldn't worry too much about it atm).
24-03-2019 7:35 AM
Moderators Note
This topic has been moved from Fibre to My Router
- My Router
