Time Based Plusnet Access Control, not being removed at end-time on PlusNet Hub One
TonyMac
I have recently enabled time based access controls to disable some devices access between 4am to 7am, on
my Plusnet Hub One (Software version 4.7.5.1.83.8.237.2.2). However what I have is that these access control
seem not to be removed when the end-time is reached. Screen shot attached. This router does know the correct time.
Deleteing the access control restored the connectivity,
Is this a known issue ?
Cheers Tony
2 REPLIES 2
DS
Seasoned Champion
Fixes: 22
Re: Time Based Plusnet Access Control, not being removed at end-time on PlusNet Hub One
Welcome to the forums @TonyMac
I've never used this feature before, but unitck the permanent - it doesn't mean block it at this time every day, it means a 24 hour daily block.
Then see how you get on Wink
(your firmware is old too, but I wouldn't worry too much about it atm).
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
