Technicolor TG582n doesn't allow to change DHCP Pool Range Through CLI
lukas
Interested
I have a telnet connection to the TG582n.
I have only one pool in DHCP:
Idx Pool              Address Range         Intf              Admin  Alloc   State
0   LAN_private       192.168.1.[200-250]   LocalNetwork      up     dynamic static
I am trying to use a simple cli command:
{lt_pdpd}=>dhcp server pool config name LAN_private poolstart 192.168.1.201, but it gives me an error:
Error : Pool address range overlaps with other pool address range.
Also tried a little bit different command:
dhcp server pool config name LAN_private intf LocalNetwork poolstart 192.168.1.100 poolend 192.168.1.109 netmask 255.255.255.128 gateway 192.168.1.110 , but it gave out another error:
Error : Unable to configure LAN_private
If I try to change the pool through GUI interface, everything works. Every comment is much appreciated.
