Technicolor TG582n FTTC Firmware update.
NathanGrimson
Hey there, I was wondering if there was a repository or area on the forums/website that i can download and install the latest Firmware for my router?
having a few issues with a Game that just released involving Strict NAT types and the like. They mentioned a firmware update might do the trick as it's been almost 3 years since we got the Router.
Much appreciated.
29 REPLIES 29
etdsaunders
Fixes: 7
Re: Technicolor TG582n FTTC Firmware update.
Do you know current version?
A search comes back with the following link
http://products.plus-payh.co.uk/firmware/
Hope this helps!! Wink
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
NathanGrimson
Yeah the current Firmware version on my router is 10.2.5.2.FO. I hope there is a newer version out there as i'm really not wanting to have to try another solution to this.
Fixes: 1,600
Hi there.
I believe the router should update itself when there's new updates available. It looks like the "link" between our servers and the router wasn't enabled, so I've just toggled it on now so hopefully an update is pushed down soon.
davefaulkner
I'm in exactly the same position - on version 10.2.5.2. Is it possible to enable the link with your servers for me so that I can get the software/firmware updated, please? Somewhat concerned about this after reading the alerts about Russians controlling domestic routers!
Many thanks.
bobpullen
Fixes: 316
As far as I know that's the latest version, and to clarify, updates are not pushed automatically to the Technicolors. Neither do I expect there'll be much more in the way of updates for the device I'm afraid.
davefaulkner
Thanks for letting me know, Bob. In that case, can I obtain a replacement router that can be kept more up to date? (And if so, from PlusNet or do I need to buy independently?) I'm keen to stay as secure as is reasonably possible.
Fixes: 1,600
@davefaulkner if you can PM me your username I'll see what we can do for you.
Fixes: 1,600
Cheers for your username Dave.
I've ordered a new router for you now, it should arrive within a few days.
davefaulkner
Thanks so much, hugely appreciated.
Fixes: 1,600
No problems Dave.
Let us know if you need any further help.
cpowell1212
Hello, I seem to be in same position.  I have a Technicolor TG582n FTTC with firmware 10.2.5.2 It seems to be giving me some problems but am I right in understanding there isn't a firmware update available for this router?
Fixes: 1,600
Hi there @cpowell1212. It's unlikely we'll be pushing anymore firmware updates to the Technicolor routers due to the length of time since we've supplied them.
What problems are you experiencing with the router?
cpowell1212
Thanks for the swift response @Gandalf
The main problem is that it seems to be dropping the connection to my NAS drive, and also to the imap server.  I've done quite a lot of investigating of the various potential causes of this but the router is looking the most likely suspect.  So updating the firmware was the obvious next step.  It sounds as though the only option is for me is to replace the router.  Is that right?  If so is there a facility for Plusnet to replace it or do I have to do that for myself?
Fixes: 1,600
Is your NAS drive connected over WiFi to your router or using an ethernet cable?
From looking through your account, I'll be happy to send you an updated and combined modem router (the Hub One) free of charge given the length of time you've been with us (Thanks for that Thumbs_Up)
Alternatively if you prefer to buy your own modem and/or router the details here should help you set it up.
Let us know if you would like a new router from us.
