Technicolor 582 with D-link cameras
- My Router
- Re: Technicolor 582 with D-link cameras
19-09-2017 3:14 PM
hi,
I have the Technicolor 582n router, which has always been ok, although wifi coverage isnt as good as the one it replaced (Draytek), but it worked.
Now I have bought some D-link wifi cameras, and they will not connect to the router.
D-link support now tell me that there is an issue between their cameras and the Technicolor routers.
"There is an incompatibility between D-Link and Technicolor devices. If your router is Technicolor, the issue could be related to that. "
Has anyone heard about this, and if it's true, do Plusnet offer any alternative Router that I can use, or another solution ?
Thanks.
19-09-2017 4:24 PM
If I remember correctly the 582 is not VDSL compatible so you're on ADSL.
You can use any modem / router you want. PlusNet supply the required details to connect on their Support pages.
For example, if you still have the Draytek unit you could try that.
19-09-2017 4:29 PM
Hi Brian,
Thanks, but I'm not sure I have the ps for the Draytek, so I wondered if Plusnet might have another I can use (Hub one or something) instead ?
If not I guess I am stuck with sourcing the ps and trying the Draytek.
best regards,
Tony
- My Router
