Talk Talk Sagemcom Fast 5364 WiFi Hub on Plusnet?
- My Router
- Talk Talk Sagemcom Fast 5364 WiFi Hub on Plusnet?
05-05-2019 10:37 AM
Any info gratefully received.....
Re: Talk Talk Sagemcom Fast 5364 WiFi Hub on Plusnet?
05-05-2019 12:02 PM - edited 05-05-2019 12:09 PM
Hi
Below are my settings on a non-plusnet router. I know nothing about the Sagecom
Login name <your account name>@plusdsl.net
Password ********
Authentication Method PAP or CHAP
Server type PPP
IP Address Server assigned
Set DNS to Get Automatically from ISP
POP3 (incoming mail) Server mail.plus.net
POP3 login name <your account name>
POP3 password ********
IMAP Server imap.plus.net
SMTP (outgoing mail) Server relay.plus.net
Your email address <your account name>@<your account name>.plus.com
05-05-2019 1:42 PM
@RPC Welcome to the forum.
Assuming that your router is compatible then do the following.
1. Disconnect the dsl cable
2. Find the factory reset facility. This should be a small hole where you can insert a paperclip or similay. Hold the switch closed for 30 seconds. Wait for the router to reboot.
3. Enter the correct settings from here, you will probably need to use the router advanced settings to get to the appropriate page. https://www.plus.net/help/broadband/broadband-connection-settings/
4. Connect the dsl cable.
Fingers crossed this will do the trick.
06-05-2019 8:01 PM
I don't own TalkTalk wifi hub, but after viewing this youtube video which 'claims' you can configure the wifi hub to use different connection protocol.
I suggest you go to the 'Internet Connectivity' button.
From there, change the 'Connection type' to 'PPPoE'
Then fill in the blanks. (if you an upload an image of this screen, it would be helpful)
Keep 'VLAN ID' as 101
Ensure you enter your full plusnet username. eg. myname@plusdsl.net
Good luck.
06-05-2019 8:29 PM
Moderators Note
This topic has been moved from Fibre to My Router
08-07-2019 12:09 PM
08-07-2019 1:53 PM
sagemcom fast 5364
That's normally supplied by TalkTalk I believe. If that's the case then it's almost certainly locked to TalkTalk and it's not possible to use with another ISP
- My Router
