Tablet losing connection
diddlyf
We recently had a new Hub router, everything has been fine for a week, but now my wife's tablet (Lenovo Tab 8 ) has started to lose the internet connection . When we try to reconnect the message either says "connected-No internet" or it says " Authorisation issue " anyone any ideas Huh
3 REPLIES 3
Fixes: 1,474
Re: Tablet losing connection
Moderators Note
This topic has been moved from ADSL Broadband to My Router
bobpullen
Fixes: 307
@diddlyf - I suspect you're subject to the problem being discussed here.
I've just pushed an update to your router that should help. You'll need to switch it off/back on at your side to apply it.
Hope it helps.
diddlyf
Thanks Rob, seems to be sorted now
