TP-Link W9980 on Plusnet ADSL
pands1
Hi I have recently bought a TP-Link W9980 to use on my PlusNet ADSL, however I have configured it using the integral plusnet adsl template and also manually but cannot get onto the internet. The DSL and internet lights are on OK which suggests it has logged into my account ok but I cannot get out onto the internet. I have tried manually configuring the DNS servers but still no go. it is the same from a wired connection as it is from a wireless which I think points to the router.  Any thoughts anyone?
Tags (1)
2 REPLIES 2
HairyMcbiker
Fixes: 21
Re: TP-Link W9980 on Plusnet ADSL
Are you getting an ip address from it? 192.168.1.xx
If so try this in a terminal/cmd
ping 192.168.1.254
ping google.co.uk
If the first works and the second fails then open a browser window and navigate to http://192.168.1.254
out in your admin details and check the status page (1st page loaded) it will tell you if it is connected.
Then check the Diagnostic page and run both the checks.
If it is synced but not connected check the system page and look at the ppp logs. You need to have user@plusdsl.net and the password is CaSe senSitIve
pands1
Hi HairyMcbiker Thanks for your reply , sorry for the delay but I have been away. Thanks for your suggestions it was a schoolboy error I had made ! I had missed out the s from .dsl in the login. Stupid me. Anyway thanks for your help it made me look more closely at what I had done, all is now working OK.
