TP-Link VR600 V2 Issue
- My Router
- TP-Link VR600 V2 Issue
09-09-2018 1:55 PM
I have installed a TP-Link VR600 version 2 router on my daughter's line.
After the installation I had a browse round the facilities and stats pages.
I came across a page called Traffic Monitor and out of curiosity I enabled it.
When I came to disable it again I received the error seen below and the monitor stubbornly refused to disable.
Has anyone any idea how this facility can be turned off please.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
Re: TP-Link VR600 V2 Issue
09-09-2018 4:42 PM
fwiw, you may get a better answer if you pose your question on the TPlink support forum.
A quick google of 'archer error 9003' suggests this error code has appeared when there is a serious hardware fault.
Perhaps check if there is a newer firmware for the router.
10-09-2018 12:43 AM
Thanks @bill888
A few people on the TP-Link forum are complaining about this bug but there is no sign of a fix yet and no firmware update.
We're hoping that TP-Link are working on it.
I did wonder if I could telnet into the router and I'll look into that when I get chance if it's not blocked by the firmware.
It may be that the Traffic Monitor isn't resource hungry and so will not matter.
02-12-2018 7:23 AM - edited 02-12-2018 7:23 AM
the same problem with tp-link vr600 Ver 2.1
Firmware Version:0.2.0 0.9.1 v0074.0 Build 170504 Rel.68210n
your version hardware of VR600 ?
i try
disable or reset Traffic Monitor get this error 9003
to disable it you must be disconnect of the internet first ! this issue me be hardware or software I do not know
02-12-2018 1:12 PM - edited 02-12-2018 1:36 PM
try this beta firmware this for tp-link vr600 Ver 2 ( EU )
https://static.tp-link.com/2018/201801/20180123/Archer_VR600_EU2.0.zip
