TP-Link Omada ER605 ADSL Hub 2 Bridge Mode??
thepix
I've seen a lot of talk regarding PPPoE connection for FTTC broadband, am I right in thinking that it's not possible to connect an ADSL broadband service via PPPoE?
I have an Omada ER605 I was trying to configure via Bridge Mode direct to the ISP, but have come up stuck so far...
11 REPLIES 11
Fixes: 586
Re: TP-Link Omada ER605 ADSL Hub 2 Bridge Mode??
@thepix
It is possible BUT you need to configure the modem correctly
what are you using as the modem ?
thepix
The Hub 2 as the modem and ER605 as the Router.
Fixes: 586
Ah!
I assume you have the Hub2 in bridge mode and the ER605 confiured for PPPoE connected via its WAN port to a Hub2 LAN port ?
The problem with ADSL bridge mode is that the encapsulation needs to be LLC and not VC-MUX (which is the default).
I dont think the Hub2 is configurable. This cropped up a while ago https://community.plus.net/t5/My-Router/HUB2-Bridge-mode-help/td-p/1893005/page/2 but I'm not sure if it ever got resolved.
https://community.plus.net/t5/My-Router/HUB2-Bridge-mode-help/m-p/1894187#M33595
thepix
Mmmmm, maybe that's my problem.  I had it connected Hub2 WAN to ER605 WAN, I'll give the Hub2 LAN a try.
Hadn't heard of LLC or VC-MUX before, just looked it up and that may be the real stubbling block as the ER605 only seems to have configuration for LLC.
Fixes: 586
No, its the Hub2 that needs to be configured for LLC. The ER605 is just a router, its WAN connection is just PPPoE with your PLusnet credentials.
IF the bug in the Hub2 in ADSL bridge mode has been fixed , then it should work , if it hasnt , then there's nothing you can do to configure it
thepix
Thanks for your wisdom on this matter.
Wish I had messaged earlier, could have had 4hrs back. 😊
Fixes: 586
@thepix  Does that mean that connecting to a Hub2 LAN port worked then ?
thepix
No, no joy...
Had to go back to Static IP connection via LAN, disable WiFi and DHCP 😔
Fixes: 586
@thepix Seems like the bug wasnt fixed then, not surprised I suspect ADSL problems are not a priority.
If you want a cheap ADSL modem then look at the Tplink td-w9970. They can be configured for ADSL Bridge mode with the correct (LLC) encapsulation. They look awful but can be picked up on ebay for less than £10 inc postage.
In fact if you're anywhere near NG10 I've got one you're welcome to if you collect...
thepix
Funny you say that, I just came back to mention it looks like I could use the TD-W9970 for the intended purpose and it's great to see you suggest the same...
Thanks again.
Fixes: 586
I only ever used mine in VDSL bridge mode but from what I can see it should be possible to configure for ADSL bridge mode with LLC encapsulation
